Cabos Speaker Qed Silver Anniversary XT (R$500,00)
Vendo cabos para trio frontal de hometheater.
01 par de cabos para caixas frontais de 1,50m cada
01 cabo para caixa central com 1,20m
Os cabos sao de minha propriedade e foram retirados da minha sala de hometheater dedicada.
Especificações dos cabos:
Su conductor tubular consiste en una trenza de tres 5x16x0.1mm. Su alma compresible teflón simplifica la conexión. Resultados: de baja resistencia, baja capacitancia y baja inductancia.
Silver Anniversary-XT has been specifically designed as the natural replacement for the multi-award winning Silver Anniversary speaker cable.
Designed with performance in mind, the Silver Anniversary-XT speaker cable boasts all of the characteristics associated with Silver Anniversary but with the added enhancement of the Aircore technology found in the prestigious X-Tube series.
TECHNICAL SPECIFICATIONS
• Unique SPOFC triple braid 5 x 16 x 0.1mm
• Compressible Teflon Aircore for ease of termination
• Low resistance, low capacitance and low inductance
• Easy strip Polyethylene outer jacket
• 2 x 1.88mm2 conductor cross sectional area
Da uma lida nas regras.
https://forum.htforumbrasil.com.br/post/regras-dos-classificados-11096812?pid=1319411451
[QUOTE username=guinepal userid=7347200 postid=1321618808]Da uma lida nas regras.
https://forum.htforumbrasil.com.br/post/regras-dos-classificados-11096812?pid=1319411451[/QUOTE]
Corrigido, obrigado e desculpa.
