ENCERRADO - Cabo de caixas Kimber Kable 16 Rohs - 1.45 Cm x 2 pernas
Cabo com 1,45 Cm X 2 pernas. PAR R$160,00
Description
An Upgraded Bulk Speaker Cable for Upgraded Sound
Dual-gauge configuration KWIK-16 from Kimber Kable boasts a large-gauge conductor and a small-gauge conductor for each channel, for four spiraled conductors in all. This unique 16-awg strand design, along with Kimber Kable's special-recipe dielectric, adds up to one of the best sounding highly affordable bulk cables for home theater and distributed sound you're ever likely to hear. The slippery PVC outer jacket pulls easily through walls.
Kimber Kable KWIK 16 is an upgraded speaker cable for upgraded sound compared to any other cable at or near the price. It excels at in-wall installations, but its performance is so good, it deserves to be used anywhere when bulk cable might be desired, such as in multichannel applications.
Dual-Gauge Strand Construction
KWIK 16 uses dual-gauge strand construction and a PE dielectric. The four-conductor design is used in hybrid braid style for two-conductor termination. One conductor of each color contains finer gauge copper strands, while the other conductor of each color contains heavier gauge copper strands. When the two gauges are combined, they serve to help minimize resonance within the cable stranding, thereby optimizing performance.
Smoother, Cleaner, and More Grain-free Sound
KWIK 16 boasts a PE dielectric that is far superior to the commonly used PVC dielectric, both electrically and in terms of sound quality. PE provides a smoother, cleaner, and more grain free sound. The off-white PVC outer jacket is durable and pulls smoothly through studs without sticking or binding. The neutral color of the jacket is a benefit with regard to decor, should the cable become visible. In addition, convenient foot labeling on the jacket makes it easier to track cable usage.
Kimber Kable KWIK 16 is 16 AWG and UL / CL2 rated. It has an outer diameter of 0.25."
Specs.
Cable gauge: 16 AWG
Outer diameter 0.25"
UL / CL2 rated
ESPECIFICAÇÕES
Maior som de qualidade e instalações de teatro personalizados em casa já não precisam ser comprometidos por um comum ‘’contratante tipo’’ cabo de alto falante.
Usando nosso processo de engenharia de Oscar ( Correlação Subjetivo Objetivo e Resultados), Kimber Kable projetou o Kwik para gerar um áudio superior a todos os outros cabos de coluna personalizados de instalação. Tendo em mente as necessidades dos In-wall e alto falantes in-ceiling, a Kimber projetou o Kwik 16 e 12 para ter clareza de médios, incrível e substancial resposta de mid-bass.
Isto é conseguido através de uma configuração única dupla vertente de calibre e nossa receita especial dialétrico PE.
O escorregadio off-white revestimento de PVC exterior e rotulagem revestimento de PVC exterior e rotulagem pé conveniente temu m ( UL ) CL2 nominal KWIK um enorme sucesso com instaladores personalizados.
Nosso 16 awg x 2 e 12 awg x 2 Cabo orador condutor contem dois brancos e dois amarelos condutores que devem ser combinados em cores para alcançar o calibre especificado e performance que foi projetada em nossa Kwik.
Frete por conta do comprador
Aceito retirada Local / S.Paulo / Bairro Moóca
Ainda disponível
Up…
Up.
Ainda disponível… aceita retirada em mãos.
faço M.Livre
Disponível… aceito troca
Up.
Disponível…
Novo valor para vender
R$140,00 o par.
Aceito retirada no local
Ainda disponível, aceito M.Livre, e retirada em mãos
R$130,00 PARA VENDER.
Up. semana!
Ainda disponível…
Up… R$130,00
Up.
(ENCERRADO) Cabo vendido, fora do Ht
Obrigado pelo espaço Ht forum Brasil, e atenção de todos.
