Super Premiada! Pequena e com uma performance sensacional! Preço menor que nos EUA! 150 dólares nos EUA. Super potente!
The Minx Min 21 takes audio excellence to the next level with a twin BMR driver configuration or even more power and greater dynamic range. Min 21 is the ideal choice for larger rooms and offers an amazing hi-fi experience whether you?re listening to soothing classics or a live rock concert!
PRODUCT
Minx Min 21
TECH SPECS
REVIEWS
NEWS VIEWS & REVIEWS
UNITED KINGDOM
“If you are looking for a very small and trendy 5.1 speaker package then it’s laborious to fault the Cambridge Audio vamper s215.”
READ REVIEW
WHAT HI-FI
UNITED KINGDOM,
“You’ll be astounded by how effectively the speakers and subwoofer work together.where space is tight, the miniscule Minx fits the bill and sounds fabulous.”
READ REVIEW
T3
UNITED KINGDOM,
“It seems inconceivable that such small cubes, which are virtually invisible when dotted around, can fill a room as easily as they do.”
FREQUENCY RESPONSE
120Hz-20kHz
IMPEDANCE
8 Ohms compatible
RECOMMENDED AMPLIFIER POWER
25 - 200W
DRIVE UNITS
1 x 2.25? BMR, 1 x 2.25" longthrow woofer
DIMENSIONS (W X H X D)
78 x 154 x 85mm (3.1 x 6.0 x 3.3?)
WEIGHT
0.75Kg (1.65lbs)
FINISHES
High gloss white
