Vendo par de caixas Q Acoustic 3020 super premiadas e com uma sonoridade muito musical.
Excelente definição e graves firmes e potentes.
Estou pedindo R$ 1700,00
Posso despachar ou pode retirar em Campinas - SP.
Seguem especificações e um vídeo com elas tocando na minha sala.
Key Features
- Like its little brother, the medium sized 3020 bookshelf speakers benefits from the advanced, low distortion, wide dispersion, new 3000 Series Concentric Ring Dome tweeter; uprated crossover and improved low resonance cabinet. In addition, it boasts a larger 5 inch drive unit, with the new Aramid Fibre/Paper cone material. This larger driver delivers an extended big bass response with fast dynamics, wonderfully open, realistic midrange and an extraordinary 'being there' three dimensional sound.
- Enclosure type: 2-way reflex, Bass Unit: 125m, Treble Unit: 25mm
- Frequency Response (+/- 3 dB): 64Hz - 22kHz, Nominal Impedance: 6ohm, Minimum Impedance: 4ohm
- Sensitivity: 88dB, Recommended Power: 25 - 75w, Crossover Frequency: 2.9kHz
Specifications:
- Bass Unit: 125mm
- Treble Unit: 25mm
- Frequency Response: 64Hz - 22kHz
- Nominal Impedance: 6ohm
- Minimum Impedance: 4.0ohm
- Sensitivity: 88dB
- Recommended Power: 25 - 75w
- Crossover Frequency: 2.9kHz
- Dimensions H/D/W mm: 260 x 226 x 170
- Weight: 4.6kg
