R$ 3.800,00
Usado, em excelente estado de conservação, funcionamento 100%.
Acompanha caixa, manuais, controle, capa e dongle BT100 de bluetooth.
DAC
Dual Wolfson WM8740 24-bit DACs
DIGITAL FILTER
2nd Generation ATF2 up-sampling to 24-bit/384kHz
ANALOGUE FILTER
2-Pole Dual Differential Bessel
USB AUDIO INPUT
USB Type B conforms to USB Audio profile 1.0 or 2.0 (user selectable)
DIGITAL AUDIO INPUTS
S/PDIF Coaxial and TOSLINK Optical
ANALOGUE AUDIO OUTPUTS
Balanced XLR and unbalanced RCA analogue
DIGITAL AUDIO OUTPUTS
COMPATIBILITY
UPnP, Local USB media, USB audio 1.0 and 2.0, S/PDIF Toslink and Coaxial, Airplay, BT100 Bluetooth receiver (not supplied), Internet radio, Spotify Connect
AUDIO FORMATS
ALAC, WAV, FLAC, AIFF, DSD (x64), WMA, MP3, AAC, HE AAC, AAC+, OGG Vorbis
MAX POWER CONSUMPTION
30W
STANDBY POWER CONSUMPTION
0.5W
DIMENSIONS (H X W X D)
Maximum including sockets and controls: 85 x 430 x 305mm (3.4 x 16.9 x 12.2")
WEIGHT
3.5Kg (7.7lbs)
