ENCERRADO - Interface asynchronous USB Peachtree Audio X1 - COAXIAL 24/192 KHz
Valor: R$ 600,00
Contato: (34) 99107-0444
Interface em ótimo estado estético e funcional.
Usa chip XMOS
Descrição do fabricante:
Upgrade your USB DAC to Asynchronous 24/192
USB inputs on many DACs don’t support resolution beyond 16-bit/48kHz. The Peachtree Audio X1 USB to SPDIF Converterinterfaces between your computer’s USB output and your DAC’s SPDIF input (coax or optical) to provide a high-resolution upgrade over your DAC’s stock USB input.
The X1 lets you fully enjoy the highest-resolution digital music available – all the way to 24-bit/192kHz resolution!
If your computer’s operating system is Windows XP, Windows 7 or Windows 8 you’ll need a small easy-to-install driver to unlock the X1’s 24-bit/192kHz resolution. No driver is needed for Mac OS X.
Bom dia!
Essa Interface é bidirecional (USB => Coaxial e Coaxial => USB) ?
Desde já agradeço.
Carlos
Bom dia @Carlos Simões, acredito que seja somente de USB para Coaxial e óptico Toslink.
Abraço.
Interface vendida para um membro.
Obrigado pelo espaço.
