ENCERRADO - Processador ROTEL RSP1572 3D - Preço: R$ XXXX
ROTEL RSP1572 3D
Motivo da venda: Upgrade
Acessórios: Acompanha controle remoto
NÚMERO DE CANAIS: 7.1
CODECS DE ÁUDIO: DOLBY TRUEHD e DTS-HD MA
ENTRADAS HDMI: 6
SAÍDAS HDMI: 2
3D: sim
CONEXÃO BALANCEADA XLR: NÃO
RESPOSTA DE FREQUÊNCIA: 20 Hz to 20 kHz
TUNER: NÃO
CONEXÃO RS232: SIM
DIMENSÕES 27 CM X 44 CM X 44 CM
 The RSP-1572 is Rotel’s latest 7.1 surround sound preamplifier. Its advanced design builds upon a progression of outstanding home theater processors that have received critical acclaim around the globe. The RSP-1572 features important new technologies such as HDMI 1.4 with 3 D capability. It offers six HDMI inputs and two HDMI outputs with one HDMI output having ARC capability (Audio Return Channel). The ARC in HDMI 1.4 enables a TV via a single HDMI cable, to send audio data “upstream” to an A/V receiver or surround audio controller, increasing user fl exibility and eliminating the need for any separate S/PDIF audio connection.
ModelRSP-1572
Input Voltage/Power120VAC and 230V
AC Operation
47 Watts Operating Power
0.4 Watt Standby PowerAgency ComplianceROHS
IECEE (CB)
ETL/CETL
CEOperating Temperature0°C to +60°COperating Humidity
90% RH at 60°CVideo Inputs
HDMI (6)
Component (2)
Composite (2)Audio Inputs
Optical (4)
Coax (3)
Tuner (1)
CD (1)
Analog Stereo (6)
Multi Input 7.1 (1)
USB (1)Video Outputs
HDMI (2)
Component (1)
Composite Main (1)
Composite Zone (3)Audio Outputs
Optical (1)
Coax (1)
Pre Out 7.1 (1)
Analog Stereo Main (1)
Analog Stereo Zone (3)Accessory Controls
Computer RS232 Control
RR-CX94 IR Remote
Learning IR Control System
12V Trigger Out (6)
Rear IR Zone Pass through (2)
Rear IR Zone In (4)
Rear Addressable IR Out (4)Video Features
Faroudja Video Scalar
ARC and CEC Enabled
3-D Pass-Through Compatible
Analog to HDMI 1080p ScalarAudio Features
Dual DSP Supports Dolby HD & DTS
7.1 +XS, +PLIIx, +PLIIz
DTS HD Master
DTS HD Express
Dolby True HD
Dolby Digital Plus
Adjustable Crossover
Speaker Group Delay
Speaker Distance Setting
10 Band Parametric EQColor Selection
Black and SilverWeight
Product Only
Peso - 12.8 KG
up
