Pausado - Processador Emotiva UMC-1 - R$2.000,00
Processador Emotiva funcionando perfeitamente (todas entradas HDMI OK) com controle e acessórios (microfone e antenas).
Excelente áudio e vídeo.  Um belo processador para iniciar no mundo dos procesadores.
Para regiões da grande SP, Jundiaí e Campinas consigo entregar pessoalmente sem taxa extra ou retirar comigo no Broklin em alguns dias da semana no horário comercial IMG_20201106_200552.jpg  IMG_20201106_200542.jpg  IMG_20201106_200537.jpg  IMG_20201106_200519.jpg  IMG_20201106_200511.jpg  IMG_20201106_200434.jpg  IMG_20201106_200428.jpg  .
Para demais localidades, posso despachar via Jadlog com adição do valor do frete.
Especificações :
  • win Cirrus 32 bit dual core DSP’s
  • Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, S/PDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
  • Multi-channel Dolby Volume
  • Genesis/ST Torino high performance scaling engine - featuring a full implementation of the Faroudja DCDi image processing suite
  • Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
  • Emo-Q automatic multi-channel room correction and loudspeaker setup. Calibrated measurement microphone included.
  • Quadruple bass manager with independently selectable  high and low pass frequencies from 40Hz – 250Hz, in 5 or 10Hz increments (depending on frequency)
  • Selectable 12db or 24db per octave high pass and low pass filters by channel groupings
  • Independent 11-band graphic EQ with global bass and treble controls by channel groupings
  • Balanced subwoofer output
  • All legacy video inputs can be scaled and output over HDMI at up to 1080p
  • 1080p/24 fps video support
  • Video pass-through mode with 12 bit compatibility
  • HDMI sources can be format converted to component video up to 1080i (subject to Macrovision guidelines)
  • HDMI 1.3a Deep Color compliant (not 3D-ready)
  • All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
  • 0.5dB level trims on all channels
  • High voltage, low impedance main analog outputs for uncompromised dynamic headroom
CONNECTIVITY:
  • 5 - HDMI inputs and 1 HDMI output.
  • 3 - composite video inputs (RCA)
  • 3 - S-video inputs  (S-video mini DIN)
  • 3 - component video inputs (RCA)
  • 1 - component video output (RCA)
  • 4 - stereo analog audio inputs (RCA)
  • 1 - 7.1 analog input set (RCA)
  • 1 - 7.1 analog output set (RCA)
  • 4 - coaxial digital inputs, (RCA)
  • 3 - optical digital inputs  (Toslink)
  • 1- coax digital audio output (RCA)
  • 1- optical digital audio output  (Toslink)
  • 1 - Stereo or 2 channel analog multi channel mix down output  for fixed level monitoring (RCA)
  • 1- stereo analog variable and independent Zone 2 output (RCA)
  • 1 - stereo analog fixed level record output (RCA)
  • High performance  AM/FM tuner with 24 FM and 6 AM presets
  • 3 - assignable trigger outputs Movie/Music/Amp (3.5mm mini)
  • 1- IR input (3.5mm mini)
  • 1 - IR output (3.5mm mini)
  • 1. Microphone input (3.5mm stereo mini)
  • 1- USB data input  (for software upgrades only)
  • Size:
    Unboxed: 17” wide x 3 7/8” high x 13” deep
    Boxed: 18" wide x 7" high x 23" deep
Venda realizada no ML - aguardando a finalização dos trâmites.
Obrigado!
