[CANCELADO] - Projetor Panasonic Fullhd 3d Pt-ae7000 Lampada Nova
Projetor Panasonic PT-AE7000 FullHD 3LCD com 3D e Lens Shift.
Valor : R$4.500,00
Bivolt Automatico.
Contraste de 300.000 e 2.000 ansi lumens
Zoom óptico e focus elétrico.
Lampada trocada e nova, com 40H de uso (lâmpada antiga original vai junto).
Video do proprio projetor , difícil de focar com câmera do celular, mas comprova o funcionamento.
White Brightness
2,000 ANSI Lumens
Resolution
1920x1080
Aspect Ratio
16:9 (HD)
Contrast
300,000:1 (full on/off)
Dynamic Iris
Yes
Display Type
2 cm 3LCD Chips
Color Processing
8-bit
Video Modes
720p, 1080i, 1080p/60, 1080p/24, 1080p/50, 525i, 525p, 576i, 576p, 625i, 625p, 1125i, 480p, 480i
Data Modes
MAX 1920x1080
3D Modes
Full HD 3D
Lamp Type
200W UHM bulb
Lamp Life
4,000 hours / 5,000 hours (Eco)
Lamp Model
ET-LAA310 Buy Replacement Lamp
Included Lens
2x Powered zoom , Powered focus
Optional Lenses
No
Lens Shift
Horizontal +/-26% & Vertical +/-100%
Throw Distance
2.4 m - 9.0 m Calculate Throw Distance
Image Size
102 cm - 762 cm
Throw Ratio
1.37:1 - 2.73:1 (D:W)
Projector Placement
For a cm diagonal screen, place the projector lens between 3.0 m and 6.0 m from the screen.
Digital Keystone
Vertical only
Projector Size
15 cm x 47 cm x 36 cm (HxWxD)
Weight
8.7 kg
Internal Speakers
No
Power
285 Watts 100V - 240V
Connection Panel
12-Volt Trigger x 2
Component: RCA
Composite: RCA
HDMI 1.4 x 3
RS232: DB-9pin
S-Video
VGA In: Dsub-15pin
Features
Full HD 3D
Additional Features
2D-3D Conversion, 480-Hz compatible LCD panels, Smooth Frame Creation 2 for motion blur reduction in 3D/2D viewing, Intelligent Lens Memory with Auto Detection, 2x optical power zoom/focus and lens shift.
Venda Cancelada.
