Passaria como novo se não estivesse aberto… usado por menos de umas 20 vezes depois de configurado.
Está integrado com a Alexa e com minha automação Scenario, e controlo as luzes por ele também.
Vendendo para fazer up para o modelo Elite.
R$ 750,00… apenas venda e posso fazer via ML.
Dúvidas é só perguntar…
Description
Product Description
Rethink your remote. We did. Logitech Harmony Touch is an advanced universal remote control for your home entertainment system with an intuitive touch screen and channel icons display.
From the Manufacturer
This is not a remote.
Harmony Touch is a one-touch wonder that’s redefining ultimate control over your home entertainment. Now you can instantly access whatever you want to watch, hear or play with a tap of a touch screen. To learn more about Harmony remotes, .
Intuitive color touch screen
Fluid, one-touch1 interaction with a vibrant, color touch screen
Smoothly swipe and scroll to your favorite entertainment options—TV channels, movies, games, Organize and re-order icons, buttons, activities, settings and more the way you like them, right on the remote music—all with one touch
New onscreen programmable gestures so you can skip, pause and access other commands more quickly
Number pad access on touch screen
Versatile touch screen doubles as a bright number pad
Fewer traditional buttons clears the way for greater comfort and style
Personalize your device
50 easy-to-customize channel icons—watch your favorite channels instantly with a simple tap2
Simply select your channel icons from a list on MyHarmony.com and save them to your remote
Create more unique favorite icons using your own, personalized images
Power within easy reach
Rechargeable—no battery hassles
Charging station keeps Harmony Touch charged, ready and always in reach
Simple, yet advanced
New on-screen swipe gestures, like volume up/down, skip and pause (all customizable) make it simpler to access immediate control
Includes advanced features, like sequences (or macros) to create the shortcuts you desire
Adjust time delays directly on the remote control to ensure all your devices have the time to change settings
One controls all
Your instant remote control consolidator—controls up to 15 devices you own today and add tomorrow
Works with virtually any device—compatible with over 225,000 devices from 5,000 brands
Future proof—online library makes it easy to update your remote with new devices and commands
Back-lit buttons for convenient navigation
Bright illumination—easy to navigate your entertainment, even in the dark
Low-profile, sculpted buttons are easier to find and press while creating a sleek look
Streamlined button layout—no mechanical number pad for a clean, elegant design that's also easier to use
Easy guided online setup
Simply connect the remote to your PC or Mac computer, go to MyHarmony.com, and download full commands for your devices
No need to enter endless equipment codes into your remote
Live customer support is ready to help if you need it
Easy shortcut setup for current owners of Harmony One
1 After initial online setup.
2 Remote screen images are for illustrative purposes. Channel availability subject to your local service provider.
Description
Product Description
One controls all
