ENCERRADO - CD Player Krell KPS-20i - pré digital
R$ 12.000,00
Vendo essa obra prima dos tempos áureos da Krell. Projeto do Dan d’Agostino.
Foi considerado por diversas revistas da época como o melhor CD player ja fabricado.
Além de player ele também é um pré digital, com um DAC primoroso, até mesmo para os dias atuais.
Equipamento nota 9+, com controle remoto e clamp original. Funcionando 100%.
É um monstro, pesando 25kg!
O valor desse equipamento fora do Brasil esta entre 2.700 a 3500 EUROS.
Krell KPS-20i
1 9 9 5 - 1 9 9 7
Krell’s most remembered CD drive
KPS-20i
integrated player with digital inputs to benefit from the integrated 20bit d/a unit
Philips CDM9Pro which is housed in a 2kg brass block.
The star shaped puck (sorry - stabilizer) sticks the CD on the spindle through a quenched field magnet ; the spindle is also modded to avoid a maximum any eccentricity of the CDs by perfect interlocking with the puck (sorry - stabilizer).
Low-stored energy feet make the balance and supply the second barrier against ever nasty vibrations.
Data extraction goes through a Motorola DSP-56002 processor operating at 66MHz and running Krell-developed software similar to those used in the Reference 64 d/a unit : “incresaed complexity allows oversampled points to be more accurately calculated”. D/A ICs are four 20bit BurrBrown PCM63.
Optional ST glass AT&T digital outputs allow connection loop through Krell’s Time Sync system.
Jitter : 0 picoseconds (KPS drive)
40 picoseconds (external inputs)
Processor : 1x Motorola DSP-50002 24-bit / 66MHz
Software : Krell-written reconstructive software operating at 705,6Khz
Dithering method : no dithering
D/A : 4x PCM-63 20-bit Colinear Burr Brown in differential configuration
Frequency response : 20Hz…20Khz (+0 / -2dB)
S/N ratio : > 135dB (60Hz)
> 120dB (20Khz)
Digital inputs :
1x AT&T / ST optical
1x AES/EBU balanced
1x coaxial RCA
1x TOS optical
Digital outputs :
1x RCA coaxial
2x AT&T / ST optical (optional)
(the 2nd AT&T can be used for Krell’s Time Sync system)
Analogue outputs :
2x analogue XLR
2x analogue RCA
Dimensions : 48cm x 12,7 cm x 36,8cm
Weight : 25kg
3428C4A7-6C81-4359-A79D-772884A66601.jpeg  E338F327-FF6E-4D85-BD69-7AAD9AB7B8AD.jpeg  F256283D-6B93-47F4-9FE7-B22DF9E1491C.jpeg  9DA25EE1-B411-45A4-8731-C733F4CA6992.jpeg  3E54BCB8-A254-4D67-A349-3557E3BD0895.jpeg
