PERMITE LIGAR ATÉ TRÊS FONTES BALANCEADAS EM UMA ENTRADA BALANCEADA DE PRÉ OU AMP INTEGRADO.
Product Description
Features
- MC103-Pro-3F is a 3-way passive stereo audio splitter. It supports 3 stereo XLR inputs and 1 output (
- MC103 is designed for customers have several music equipment with XLR balanced output. You can conveniently switch among different sound sources and compare their sound performance (for 3-IN-1-OUT version)
- All aluminum shell to effectively avoid external noise and guarantee high-quality signal transmission; NEUTRIK gold-plated XLR ports to ensure high reliability electric connection and minimize signal attenuation during its transmission.
- Each channel has been connected with shielding wire to avoid interference from outside and make sure lossless signal transmission.
- Passive audio switcher, no impact on the sound quality; with silver-plated contacts to ensure its smoothness; with HOT / COLD simultaneous switching mode and GND common terminal.
- Exquisite appearance with mini size; can be easily placed and carried to enjoy the charming of music everywhere.
