ESTOU COLOCANDO À VENDA OU PARA TROCA POR COMPONENTE QUE ME INTERESSAR ESTE PLAYER DE CD E DVD PARA ARQUIVOS GRAVADOS EM ATÉ 24/192 WAV. POSSUI SISTEMA DE BUFFER MEMORY LENS QUE ELIMINA JITTER E ERRO DE LEITURA NO CD E DVD. POSSUI SAÍDAS PADRÃO SPDIF, AES/EBU E HDMI VIA I2S.
BASE DE PREÇO PARA VENDA. USADO NO E BAY USA USD1.900,00 (VENDO POR 10 MIL REAIS)!!! ESTUDO TROCA + MEU TOCA DISCOS DR. FEICKERT WOODPECKER (SEM BRAÇO NEM CÁPSULA) POR TOCA DISCOS SUPERIOR SEM BRAÇO E SEM CÁPSULA.
APARELHO ORIGINALMENTE EM 220V QUE FOI CONFIGURADO EM 110V PODENDO FACILMENTE VOLTAR PARA 220V.
PERFEITO PARA QUEM TEM DAC COM ENTRADA DIGITAL AES/EBU OU HDMI I2S.
SOMENTE VENDENDO PORQUE PAPAI NOEL ESTA TRAZENDO O MODELO NOVO QUE TOCA SACD TAMBÉM.
NÃO POSSUO E NEM PRECISA DE CONTROLE REMOTO POIS TODAS AS OPERAÇÕES SÃO NA TELA DE TOUCH SCREEN. ACOMPANHA CABO HDMI AUDIOQUEST HDMI 3 COM 6,1% DE PRATA EM COBRE OFCC. FUSÍVEIS TROCADOS POR HI-FI TUNNING SILVER.
High resolution audio on DVD
The future of audio is to be found in higher resolution media than CD’s which are limited to 44 kHz and 16 bits. The PWT can certainly play standard CD’s directly but because the PWT is a high resolution audio transport, it can also read WAV files directly off a DVD and present jitter-free digital music to your DAC with resolution up to 24 bit and samples rates as high as 192 kHz.
High resolution downloads from sites like HD Tracks can easily be converted from FLAC or ALAC to WAV files on your computer, transferred to a DVD and played in all their high resolution glory on the PWD.
Cover art and song titles
Building the perfect transport means more than just producing the perfect output. The transport should also be a joy to use and answer a higher level of expectation from its owners.
60 years after the introduction of the vinyl LP, there are still very few players that recognize and display cover art and song titles from the disc itself. Once connected to an internet capable network connection, the PWT will display the cover art and song titles of just about any CD you place into it.
Imagine how much closer to the music you’ll find yourself with the picture of the artist on your player.
Every time you play a disc in your PWT a copy of the cover art and song titles are kept for you on your own private library page, accessed through our website. From your personal page on our website it is a simple matter to correct any of the CD’s information, change cover art and polish your CD collection.
Asynchronous audio
The PWT’s CD/DVD read device is a DVD ROM drive like that in a computer. This type of optical drive allows the PWT to read the music on the disc using an entirely different approach than that of a traditional transport or CD player.
To get bit perfect results without traditional error correction the PWT uses a multiple read technique which reads the data on the disc until it’s verified as bit perfect. Once confirmed as perfect it is then added to the Digital Lens memory.
Once in the Digital Lens solid state memory there is no clock information attached to it – just the raw and pure music extracted from the disc.
The output of the Lens is then forwarded to the PWT output through a fixed high precision, low jitter asynchronous clock. The PWT is one of the few true asynchronous transports in the world.
What does this mean to you? Better sound – in fact, far better sound. Gone are the digital artifacts we become so used to. With the Memory Player you hear every detail on your disc and that’s a revelation for many.
I2S through HDMI output
There are two ways to get the digital audio data out of the PWT: S/PDIF or I2S HDMI. I2S is the preferred method if you have the PS Audio PerfectWave DAC or any manufacturer’s DAC that can receive it.
S/PDIF (and AES/EBU) are the standard delivery methods and available on the PWT but are not the best sounding ones.
Standard digital outputs take three separate internal clocks along with the raw music data and combine them into one stream to the DAC. This mashup of music and clocks causes the audio to sound flat and harsh compared to I2S and is one of the reasons we designed NativeX on thePWD. NativeX eliminates many of the problems associated with S/PDIF.
A much better way of delivering the music is what I2S does and the audible results are stunning. Simply use any HDMI cable between the PWT and the DAC and you are transferring data perfectly, through I2S.
A growing number of DACS and devices are adopting the PS Audio HDMI standard for digital audio transmission because of its superior audio quality.
Digital Lens inside
Inside the PWT there is a built-in Digital Lens that stores the music from your disc before playing it. Unlike other approaches it is unnecessary to play the entire disc and place it into memory before listening. Instead, the intelligent Digital Lens stores only what is needed for perfect playback and the user experience is nearly instantaneous.
Just push play as you would on any CD player and the PerfectWave Memory Player does the rest instantly.
If you wish to see the lens in action, simply eject the disc while you’re listening and note how the music continues to play even when the disc has been removed from the PWT .
It is the fact that you are listening to the stored version of what’s on the disc that helps the music sound so lifelike and spacious. CD players all stream music directly off the CD while a PerfectWave Memory Player always plays out of its memory; never the disc.
The net results of this technology breakthrough is stunning sound – perhaps for the first time on your system. Music played on the PWT is simply breathtaking, full, spacious and alive as no other player can do.
The chassis of the PWT is a metal sculpture that rivals the best ever built. A combination of aluminum and steel, the PWT weighs in at 20 pounds of elegance and beauty. The top cover is a hand painted, hand polished piano black cover that has been lavished over for hours.
