Comprei recentemente numa loja holandesa duas unidades. Vou utilizar uma com meu Project Debut Carbon DC e estou colocando a outra a venda.
Preço: R$ 1.100,00
Está sem uso, mas possui algumas pequenas marquinhas como mostrado nas fotos.
É o modelo que serve na série Debut e 1Xpression.
Turntable platter
Functional and easy to use sound improvement!
Upgrade your Debut or 1Xpression turntable to „Esprit“-standards. Acryl it is made from acrylic with satinised surface and brings a more liquid sound that leaves no space for platter resonances.
The change is easily made: just exchange your metal platter for Acryl it. Unlike metal platters, where you will need to place a felt met between record and platter to damp metal resonance, you can put your record directly on the acrylic surface, with nothing in between. Acryl it is able to improve overall performance significantly!
