MUITO NOVO - 100% FUNCIONANDO - SEM DETALHES
COMPLETO COM CONTROLE + CAIXA + MANUAIS + MICROFONE CALIBRAGEM
FIRMWARE ATUALIZADO
VOLTAGEM: 127V
Altura: 174mm / Largura: 435mm / Profundidade: 326mm / Peso: 8,8Kg / Consumo: 400W
Receiver 5.2 canais, 80 Watts RMS a 8 Ohms
Modelo conta com Scaler de vídeo Qdeo para resolução 4K. Função PIP (Picture-in-picture).
7 Entradas HDMI 1.4 compatíveis com CEC, DeepColor, LipSync, Dolby TrueHD, DTS-HD Master Audio, DVD-Audio, Super Audio CD Multichannel PCM, ARC e 1 Saída HDMI, Conexão Direct Digital para iPhone /iPod via USB Frontal, radio AM/FM, Internet Radio, streaming de áudio por rede. 2 entradas USB, DAC Burr-Brown 192kHz – 24 Bits, processador DSP de 32 Bits, decodificador para todos os sinais de áudio atuais incluindo Dolby TrueHD e DTS-HD Master Audio, Room Correction & calibration (microfone original incluso).
Audyssey 2EQ. Transformador superdimensionado.
Zona 2 com saída Pré-Out que pode ser usado para 7.2 canais no mesmo ambiente.
Portas Bi-direcionais RS 232 e Ethernet (rede) para automação.
Controle remoto original completo.
AMPLIFICAÇÃO:
Channels: 5.2
Power Output (8 ohms, 20 Hz–20 kHz, 0.7%, FTC): 80 W/Channel
Power Output (6 ohms, 1 kHz, JEITA): 160 W/Channel
Amplifier Frequency Response (WRAT): 5 Hz–100 kHz/+ 1 dB, -3dB
Continuous 6 ohms Rated
Discrete Output Stages for All Channels
Push-Pull Amplifier Design
2 x Independent Power Supply
High Quality Extruded Aluminum Heatsink
PROCESSAMENTO:
Dolby TrueHD, Dolby Digital Plus Decoding
DTS-HD Master Audio, DTS-HD Express Decoding
Dolby Pro Logic IIz (Front High Channels)
Audyssey Room Correction & Calibration: 2EQ
Audyssey Dynamic EQ & Dynamic Volume
Audyssey Movie / Music Modes
Game Surround Modes (Rock, Action, Sports, Role Play)
Advanced Music Optimizer to Enhance Compressed Audio Files
DSD Processing: 192 kHz / 24-Bit Audio DAC
32-Bit DSP Chip for Advanced Processing
Ultra-Low-Jitter Circuitry to Improve Audio
Adjustable Crossover by Channel Pair: 40/45/50/55/60/70/80/90/100/110/120/130/150/200 Hz
Accurate Speaker Distance Setting: 0.2-foot
A/V Sync Delay (by Source): 800 ms
Multi-Band Speaker EQ: 5 Band
Picture Control Settings per Source
REDE:
Network Audio Steaming (Windows 7, DLNA v1.5 Certified)
“Home Media” Sharing
Apple Lossless, DSD, Dolby TrueHD Playback via Network
Pandora, Rhapsody, vTuner, SiriusXM iRadio*
Spotify, Slacker, Aupeo!, Last.fm*
USB Input for Streaming Audio: (Front & Rear)
Wireless Network Ready via USB: (Optional UWF-1)
Bluetooth Ready via USB: (Optional UBT-1)
Firmware Updates via Network / USB
Firmware Update Notification
MULTIZONA:
Fixed or Variable Zone 2
INTEGRAÇÃO:
Bi-Directional RS-232 Control Port
Bi-Directional Ethernet Control Port
Rear Panel IR Input / Output: 2 / 1
RIHD (Remote Interactive over HDMI)
RI System Control
12 V Trigger (w/Adjustable Delay): Assignable (x3)
DIVERSOS:
Pre-Programmed
GUI for Remote Control Programming
GUI for Setup Menu
Home Menu / Quick Setup Menu
Input Name Edit
HDMI Standby “Through” Mode: (Selectable)
Setup Store & Recall Function
Screensaver Function
Hybrid Standby to Reduce Power Consumption
Solid Aluminum Front Panel
Aluminum Volume Knob: (Sand Finished)
Detachable AC Cord
OBS: a última foto é ilustrativa, somente para mostrar as conexões traseiras.
.jpeg)
