VENDO OU TROCO POR CABO DE CAIXAS!
Valor: R$5.800.00
PRÉ PROCESSADOR CARY CINEMA 11
COR: SILVER
CONDIÇÃO: USADO
Estado de Conservação: 9/10
NÚMERO DE CANAIS: 7.1
CODECS DE ÁUDIO: DOLBY TRUEHD e DTS-HD MA, DTS-NEO 96/24, DOLBY PLIIX
CONEXAO BALANCEADA XLR: SIM
RESPOSTA DE FREQUÊNCIA: 2 Hz to 96 kHz
TUNER: NAO
CONEXAO RS232: SIM
DIMENSOES 45 CM X 11.4 CM X 42 CM
Decoding Ability Dolby True HD
Dolby Digital Plus
DTS-HD Master Audio
DTS-HD High Resolution Audio
Dolby Digital
Dolby Pro Logic IIx for movies and music
Dolby Digital EX
DTS ES 6.1 Discrete
DTS NEO 96/24 for movies and music
Matrix Surround for 5.1, 6.1 or 7.1
Inputs 7 RCA analog stereo input pairs
1 XLR analog stereo input pair
1 XLR digital input
7 RCA coaxial digital inputs
7 TOSLINK digital inputs
Multi channel Analog Input 7.1 analog bypass input set for multi-channel playback
Outputs Main Front pair, Center Front, Surround Back pair or Center Surround, Surround pair, Subwoofer, can have 5, 6 or 7 speakers & subwoofer, RCA and XLR connections. 2nd zone output: 1 digital output, 1 RCA analog stereo pair
Frequency Response 2 Hz - 96 kHz
Amplitude Linearity +/- 0.2 dB (20 Hz - 20 kHz)
Phase Linearity 3 degrees (20 Hz - 20 kHz)
Dynamic Range 115 dB (1 kHz)
Signal-to-Noise Ratio 115 dB (1 kHz)
Channel Separation >100 (1 kHz)
Total Harmonic Distortion 0.008% (1 kHz)
Rated Output Level 1.0 V RMS (8.0 volts maximum)
Power Input 120 or 240 Volts AC, 50-60 Hz
Power Consumption 25 watts
Weight 25 lbs
Dimensions 17.7" W x 4.5" H x 16.5" D
Detailed Features Auto setup with a microphone, RS-232 port on back panel for custom install system control, IR repeater input and output, 3 remote DC triggers, Bass and Treble controls with bass management circuit, Variable crossover from 40-140 Hz, in 10 Hz steps, dedicated remote control handset, second zone audio analog and digital outputs.
