[VENDO] Pré AMP + Power AMP Rotel Stereo - R$ 3500
Amigos, vendo esse conjunto modular composto por um STEREO PREAMPLIFIER RC-972 e um STEREO POWER AMPLIFIER RB-971 da conceituada fabricante inglesa de equipamentos Hi-Fi ROTEL.
O pré acompanha controle remoto RR AT92.
Acompanha também um DAC para quem quiser plugar áudio digital de um streamer ou smart TV, por exemplo.
Manufacturer: Rotel
Model: RC-972
Type: Preamplifier
Year of manufacture: 1998 - 2000
Color: Black
Remote control: Yes
Power consumption: 10 W
Dimensions: 440 x 72 x 286 mm (WxHxD)
Weight: 4.3 kg
Original price approx.: 699 DM
Connections
Number of inputs: 6 stereo RCA jacks
Tuner, CD, 2x AUX, Tape, Video (only sound): 50 mV / 24 Ohm
Number of outputs: 4 ( 3x stereo cinch sockets; 1x 6.3mm jack socket)
Tape, 2x power amplifier: 1 V / 100 Ohm
Headphones (6,3mm jack plug)
Technical Data
Frequency response: 4 - 100,000 Hz (+0, -3.0 dB)
distortion factor: </= 0,004%
Signal-to-noise ratio: 95 dB
Stereo channel separation: -
Tone control
Bass: Yes (+/- 6 dB / 100 Hz)
Treble: Yes (+/- 6 dB ( 10 kHz)
High Filter: No
Low Filter (Subsonic): No
Mute: Yes
Direct/Line-Straight: Yes
Special Features
IF remote control
IEC mains socket for power supply
1 Euro mains socket for power supply
Model: RB-971
Color: black
Type: Class A/B analog stereo power amplifier (mono bridgeable).
Power consumption: 250 watts
Dimensions: 440 x 92 x 334 mm (WxHxD)
Weight: 7,2 kg
Connections
Number of inputs: 1
1,0 V/33 kOhm
Number of outputs:
1 loudspeaker pair
Technical Data
Continuous power (at THD).
8 Ohm: 2 x 70 Watt RMS (20-20.000Hz, <0,03%)
4 Ohm: 2 x 110 Watt (1kHz, 1% THD)
Peak current: 30 A (0.1 Ohm, 10µs, 1 pulse)
Total harmonic distortion: <0.03%
Intermodulation distortion (60Hz: 7kHz=4:1) <0.03%
Attenuation factor: 500 (20 to 20,000Hz, 8 ohms)
Frequency response: 10 - 100,000 Hz (+0.5,-3dB)
Signal-to-noise ratio: 116 dB (IHF, A network)
Protect circuit: No
Mono circuit: 180 W into 8 ohms
Preço: R$ 4.000,00 - dos quais 10% serão doados à manutenção do nosso estimado HTFórum!
Estou em Porto Alegre/RS - Frete por conta do comprador
FOTOS:
Up! Aceito ofertas! :smiley:
UP do anúncio com DOWN no preço: apenas R$ 3500!!!
UP do anúncio: apenas R$ 3500!!!
Subindo o anúncio e baixando o preço: R$ 3.000 por um pré + amp Rotel!
Três. Mil. Reais. :grinning_face:
Galera apenas R$ 3.000 por um pré + amp Rotel!
Parecem bem cuidados :+1:
Opa! E estão! Abs!!! :grinning_face:
UP com DOWN de preço: R$ 2500,00 por um conjunto PRÉ + POWER ROTEL!
UP: R$ 2500,00 por um conjunto PRÉ + POWER ROTEL!
UP: R$ 2500,00 por um conjunto PRÉ + POWER ROTEL! :oncoming_fist: :high_voltage: :oncoming_fist: :high_voltage: :oncoming_fist:
Up de Ano Novo: conjunto PRÉ + POWER ROTEL por apenas R$ 2.500,00!!!
Up de 2026: conjunto PRÉ + POWER ROTEL por apenas R$ 2.500,00!!!
Segue à venda esse combo pré + amp Rotel, façam suas propostas!!!
Segue à venda esse belo combo PRÉ + POWER stereo da conceituada marca britânica Rotel!
Segue à venda Pré + Power Rotel! :+1: :+1: :+1:
