Vendo Projetor com Menos de 680 horas de uso
Interesse em troca por DAC
Valor do Produto R$ 20.000,00
Brightness 1,300 ANSI Lumens
Resolution 3840x2160
Aspect Ratio 16:9 (4K HD)
Contrast 60,000:1 (full on/off)
Dynamic Contrast 600,000:1
Dynamic Iris Yes
Display Type LCoS x 3
Color Processing 8-bit
Video Modes 720p, 1080i, 1080p/60, 1080p/24, 1080p/50
Data Modes MAX 3840x2160
3D Modes Full HD 3D
Lamp Type 230W NSH bulb
Lamp Life 4,000 hours
Projector Size
22 cm x 46 cm x 51 cm (HxWxD)
Weight 14.3 kg
Audible Noise 19 dB
Power 360 Watts 100V - 240V
Connection Panel
12-Volt Trigger
HDMI x 2
Network: RJ-45
RS232: DB-9pin
Features
Case Color Options
THX Certified
Full HD 3D
